Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > DX'ing
Vecchio 22-11-18, 09:56   #1
IN3ZNR
L'avatar di IN3ZNR
Registrato dal: Aug 2008
F6ARC e i DX Cheaters
Buongiorno a tutti,
tema ormai trito e ritrito quello del QSO DX ad orari impossibili in particolare sulle bande basse a partire dai 40 metri. Viene segnalato sul reflector del Clipperton DX Club (al quale accedo come immeritatamente socio) una presa di posizione (ormai datata in verità) di F6ARC Olivier, su quanto successo a lui dalla Guadalupa e da quanto segnalato da una stazione californiana. Molto edificante il fatto che in due casi segnalati ci siano italiani. Lo so che non serve a nulla e che tanto ormai la pratica è consumata e attuata di routine senza ritegno alcuno, ma mi fa riflettere quanto dice l'OM americano: tali comportamenti e abitudini così sconfortanti e demoralizzanti, mi hanno fatto abbandonare il DXing.
Se volete saperne di più andate sulla sua pagina QRZ.com
Cheaters beware!
Many of us have witnessed how some so-called DXers will use any means to better their DXCC standings, particularly on 80 and/or 160m. Whether it be using WebSDR for receive or out-of-country remote for transmission, it seems some won’t hesitate in crossing the line.
To our amusement, they often shoot themselves in the foot, in openly demonstrating their lack of knowledge of propagation on these bands. Such was the case for an Italian IK2*** who, in 2017, responded to my CQ on CW, 20 minutes prior to my sunrise in FG (10:00z) on 80m. He was 599! I ignored him and continued calling CQ. His calls were followed by an F5***! Same signal, same treatment.
Last but not the least, this message received from California, USA: “the two callsigns I heard on 40m last night were SV2*** and DD5**. It was clearly the same transmitter, because the signal was not clean, and had the same artifacts for both callsigns. It was quite loud, and I was not able to hear any other EU stations on the vertical antenna at the time. Just now (0503 - 0510Z), I heard callsigns I1***, I2*** and DF2** work E6Y on 80m CW. The also all appeared to be the same signal (same strength and fist), and much too loud. This behaviour is so disheartening. It makes me want to give up on DXing”.
I deliberately omitted their suffixes, they will probably recognize themselves
This year, should I have any doubts about the use of WebSDR (delays in responding) or remote transmission (abnormal signal strength in comparison to others from the same region), such calls won’t be confirmed in my log. In addition to the above measures, should I receive calls from multiple callsigns in series, each with the same signal, same keying and tone, only the first callsign will reach my log. So be sure your callsign is the first used!
73! Brix
Vecchio 22-11-18, 11:02   #2
Re: F6ARC e i DX Cheaters
Eh, vero, ma forse cosa un pò troppo impegnativa, soprattutto in spedizione, quando l'operatore è concentrato a "buttare" dentro call...
MA, dopo, in post produzione (come si dice per foto e video...), si potrebbe togliere dal log, quell'unico italiano a log in 10m in una spedizione dal pacifico alle 2z, per dire un esempio limite ecco, qso assolutamente non genuino.
Sarebbe un messaggio chiaro a chi ha confuso l'hobby della radio con qlc altro...
In ogni modo, quell'Oliver li mi piace :
Oliver, F6ARC will again be QRV as FG/F6ARC from Guadeloupe (NA-102) during a two week period in November/December 2018. Dates to be determined. Entry in the CQWW CW Contest, single band. Outside the contest, focus on low bands using CW (no FT8). Logs will be uploaded to LoTW and eQSL upon return home.
Vecchio 22-11-18, 14:46   #3
I5NSR
Registrato dal: Aug 2017
.....buon pomeriggio.
L' efffetto "carota" ( dxcc ) miete ancora vittime.
enneesseerre
I5NSR non  è collegato   Rispondi quotando
Vecchio 23-11-18, 17:04   #4
IN3ZNR
L'avatar di IN3ZNR
un interessante soluzione che come si dice "salverebbe capra e cavoli"
un WEBSDR utilizzabile da tutti, come ricezione per esperimenti vari, divertimento personale, curiosità sulla propagazione:
un RX remoto installato a Singapore e gestito da 9V1RM con un ritardo di 10 secondi sulla rx effettiva: semplice ed efficace
contro ogni tentazione.
Come scrive 9V1RM :
"sappiate che onde prevenire imbrogli durante le spedizioni DX o nella caccia al DXCC, c'è un ritardo di 10 secondi
nella ricezione del segnale audio di questo Websdr"
contro ogni tentazione ...anche la più subdola...come un qso in più per arrivare a 3000 nella challenge..
73! Brix
Nome:   9V1RM websdr.jpg‎
Visite: 39
Dimensione:   99.3 KB
Vecchio 23-11-18, 18:39   #5
Originariamente inviata da IN3ZNR Visualizza il messaggio
Come scrive 9V1RM :
73! Brix
Soluzione molto interessante !! Da proporre e pubblicizzare, vediamo.
Il problema.. il problema è che alcuni WebSDR, ho notato essere presi letteralmente d'assalto quando c'è una spedizione nei loro paraggi, ed alcuni, chiedono una psw quando sono così saturi, se hai la psw puoi entrare, immagino "scalzando" qualcuno degli utenti senza password, che questo accesso lo si dia solo in cambio di una transazione Paypal è ovviamente solo una mia pensata, e mal pensante quale sono sicuramente pecco, pecco enormemente.
Ma ci indovino....
Ma mi spingo molto oltre, è il black friday è tutto gratis...
Ormai è uso comune usare i websdr e similari per fare qso sulle BB dove non si ascolta un segnale, in 80m in questi giorni ci sono pileup intensi di italiani su A35EU, stazione che davvero, ascoltano in pochi, arriva bassa in beverages lunghe mezza provincia, eppure sono a chiamare.
Sono convinto che se tutti mettessero il ritardo di 10 secondi, qualche spedizioniere sarebbe pur disposto ad aspettare 10 secondi la risposta al IZ5CML 599 pur di portare a termine i qso, con stazioni che per essere a log in 80 o 160m (un domani in 60m) e per avanzare nel challenger, hanno elargito pure contribuzioni alla spedizione !
Altro che 10 secondi.. mezzora !
Continuo a peccare...
Ultima modifica di IZ5CML; 23-11-18 a 18:45
Vecchio 24-11-18, 15:14   #6
IU5BJS
Registrato dal: Jan 2018
Non dici male, eh...vile denaro !!!
Tutti gli orari sono GMT +1. Attualmente sono le 03:56.
