ARRL-10m and propagation
  • ARRL-10m and propagation
    (italiano più giù)
    look below for the final contest-plan resulting from this work
    click here
    The ARRL Contest-10m is approaching. It would be a shame not to participate right now that 10m are finally open via F2 layer.
    I think it is good to strike while the iron is hot ..
    Like I do almost every time I participate to a contest in single band singole operator category, I began to realize a sort of contest-plan related to the likely openings in the 10m to the various areas of the globe.
    In addition to the aid of the usual VOACAP-based software (WinCAP in particular), I thought this time to establish the realization of the contest-plan on the actual conditions encountered in radio from here to the eve of the contest, so then they can be compared with those estimated with software and derive from this comparison a contest-plan closer to reality.
    How am I taking into account the conditions really encountered in radio ?
    I'm using the CW-skimmer by VE3NEA combined with GPcluster by IH9GPI.
Nome:   gpi_skimmer.jpg
Dimensione: 214.5 KB
    This software contains a very interesting resource.
    In particular, it allows to export in Excel format the sequence of spots received from the dxcluster. In my case, I set as the node only the local CW-Skimmer. Thus, the spots on which the next job will then be made ​​with Excel, are those of the stations actually heard from my receiver (Perseus with CW-Skimmer with omni-directional antenna).
    The above work of listening, reporting and filing stations will run automatically on a daily basis, for all 24 hours of the day.
    On the basis of the excel file each day, then proceed to make the necessary statistics, obtaining in practice, the hourly number of stations received from Asia, Europe, South America etc.. thereby resulting in the opening and closing graphs to the respective areas. These graphs are then compared with those resulting from the VOACAP-based software and you'll get the final contest-plan.
Nome:   plan.jpg
Dimensione: 92.6 KB
    click here
    __________________________________________________ _______________________
    Il contest ARRL-10m è ormai prossimo. Sarebbe un vero peccato non parteciparvi proprio ora che i 10m sono finalmente aperti via strato F2.
    Penso che è bene battere il ferro finchè è caldo..
    Come faccio quasi sempre quando prevedo di partecipare ad un contest come singolo operatore singola banda, ho cominciato pure stavolta a realizzare una sorta di contest-plan relativo alle probabili aperture in 10m verso le varie aree del Globo.
    Oltre all'ausilio dei soliti software VOACAP-based (WinCAP in primis) , ho pensato questa volta di fondare la realizzazione del contest-plan anche sulle effettive condizioni riscontrabili in radio da qui alla vigilia del contest, così poi da poterle confrontare con quelle stimate con i software e ricavare da tale confronto un contest-plan più vicino alla realtà.
    In che modo sto tenendo conto delle condizioni riscontrabili in radio ?
    Sto utilizzando il CW-skimmer di VE3NEA abbinato al GPcluster di Giacomo IH9GPI.
    Quest'ultimo software contiene delle risorse davvero interessanti.
    In particolare, consente di esportare in formato Excel la sequenza di spots ricevuti da uno dei dx-cluster preimpostati. Nel mio caso, ho impostato come nodo da cui ricevere gli spots solo il CW-skimmer locale. In tal modo, gli spots su cui verrà poi fatto il lavoro successivo con Excel, sono quelli relativi a stazioni realmente ascoltate dal mio ricevitore (Perseus con CW-skimmer con antenna omnidirezionale).
    Il suddetto lavoro di ascolto e segnalazione/archiviazione automatica delle stazioni ascoltate verrà eseguito giornalmente, per tutte le 24 ore del giorno.
    Sulla scorta del file excel di ciascun giorno procederò poi a fare le opportune statistiche, ricavando in pratica il numero orario di stazioni ricevute da Asia, Europa, Sud America etc. ottenendo in tal modo dei grafici di apertura e chiusura verso le rispettive zone. Questi grafici verranno poi confrontati con quelli risultanti dall'uso dei software e se ne ricaverà così il contest-plan definitivo.
Nome:   plan.jpg
Dimensione: 92.6 KB
    Mi farebbe piacere leggere il vostro parere in merito, come pure eventuali suggerimenti.
    Re: ARRL-10m e propagazione
    che dire.....pare roba di fantascienza e l'hai esposta come se fosse una banalità pure io ho capito come fare!
    Grandissimo Art!!!!
    Buona preparazione!!!
    73 de Gabry IT9RGY
      Molto interessante l'analisi in tempo reale della propagazione con relativa archiviazione per valutazioni successive....
      Art non ci deludi mai !
      Vai avanti che ti seguiamo...
        Interessante Art...bel lavoro....utile
        73 Tony IK1QBT
          Aehm... non è che si può fare una cosa del genere anche in 160 metri?
            Certo Paolo che si puo' fare in 160m ( ovviamente nel contesto di una banda "magica" e imprevedibile come i 160m), basta disporre di un SDR, cwskimmer e un'antenna omnidirezionale. Intanto ho scoperto che il software di Giacomo dopo un po' sovrascrive i nuovi spot sui precedenti. Ovviamente coo' non va bene e ho gia' informato Giacpmo del bug. In alternativa sto usando Dxmonitor di VE3SUN. Questo non consente di salvare direttamente in formato excel ma pare non avere problemi con grosse quantita' di spot. Stasera potro' tirare le somme del primo giorno di ascolto dei 10m. Domani ripartira' il tutto per il secondo giorno e cosi' via fino alla vigilia del contest. Appena avro' redatto dei grafici li mettero' qui on line. Ribadiscp che non c'e' nulla di fantascientifico, le stregonerie le lascio volentieri ad altri Tutti possono replicare questa esperienza, anzi sarei interessato a confrontare i miei grafici con quelli pttenuti da altri nella loro location.
            Ultima modifica di IK7JWY; 02-12-11, 17:26.
              Ecco i primi grafici sulle aperture effettivamente riscontrate in aria in banda 10m oggi 2-12-2011. Per ora solo i tre target più significativi: EU, JA, NA
              Fare click sulle immagini per ingrandirle. Il significato credo sia immediato. Per eventuali richieste di chiarimenti sono qui.
              Japan (in JN90AB)
Nome:   JA02122011.jpg
Dimensione: 47.5 KB
              Europe (in JN90AB)
Nome:   EU02122011.jpg
Dimensione: 52.7 KB
              North America (in JN90AB)
Nome:   USA02122011.jpg
Dimensione: 52.1 KB
              Ultima modifica di IK7JWY; 03-12-11, 18:38.
                Capito. Mi sto chiedendo come funzionerebbe se al posto di un' unica antenna ce ne fossero diverse. Poi è chiaro che bisognerebbe collegarle con degli splitter, però sarebbe interessante vedere cosa si rimedia analizzando le direzioni dalle quali proviene la maggior parte dei segnali, tipo nord-ovest per gli USA, nord-est con i JA ecc... la faccenda è promettente.
                  Mah, per questo lavoro credo sia meglio utilizzare una omnidirezionale. In pratica interessa ricevere il maggior numero di spots da qualsiasi direzione e non privilegiare, con una direttiva per esempio, una direzione rispetto alle altre. Infatti, se si utilizzasse una direttiva puntata in Nord America, è chiaro che i segnali provenienti dal altre direzioni sarebbero di meno e si andrebbe così ad alterare artificialmente il risultato finale.
                  Intanto, sempre e solo con gli spot di ieri ho provveduto a integrare e mettere insieme i grafici relativi alle varie aree ed ecco il risultato:
                  (openings in JN90AB)
Nome:   openings.jpg
Dimensione: 140.6 KB
                  Ultima modifica di IK7JWY; 03-12-11, 18:37.
                    Re: ARRL-10m and propagation
                    Questo grafico è davvero interessante! Mi piacerebbe se tu potessi ripetere l' esperimento più avanti anche nelle altre bande alte, specie in 12 e 17 metri. Vedo che è ancora un po' presto per l' Oceania, aspettiamo un incremento dell' attività solare... facendo gli scongiuri.
                      Purtroppo sulle altre bande , come sai, non ho antenne. Veramente per farmi una omnidirezionale per i 12 o i 17m non è che ci voglia molto, ma quella che manca è la volontà..
                      Intanto, ecco i grafici relativi al secondo giorno (3 dicembre). Notevole la quantità di stazioni Europee ricevute ieri, insieme alle altre.
Nome:   openings_3.jpg
Dimensione: 136.0 KB
                        Ecco il grafico di giorno 4 dicembre. Purtroppo, deve essersi verificato un problema con il file degli spots, perchè sono andati persi quelli delle ore centrali. Da qui l'evidente anomalia nei grafici.
                        Giacomo GPI mi ha risposto e forse riesco a tornare a GPcluster. Sistema in prova.
Nome:   openings_4.jpg
Dimensione: 142.7 KB
                          Anche stavolta qualche oscuro imprevisto ha impedito un lavoro completo. Torno infatti a casa dopo aver lasciato tutto in perfetto ordine e mi accorgo che CWskimmer è andato in tilt esattamente 10 minuti dopo che ero uscito di casa, alle 16:30 locali
                          Questi sono i grafici di oggi 5 dicembre.
                          Comunque qualche considerazione si può fare: oggi le condizioni erano peggiori di quelle dei giorni precedenti. Pochi JA, poca Asia, poca Europa etc
Nome:   openings_5.jpg
Dimensione: 108.3 KB
                            Il software GPcluster di Giacomo era OK, quindi sono tornato ad usare quello, che tra l'altro, oltre alla comodità di poter salvare direttamente in formato Excel, elenca anche gli spots per continente.
                            Ecco, dunque, i grafici di oggi 6 dicembre.
                            opening Asia in JN90AB
Nome:   asia_06122011.jpg
Dimensione: 63.4 KB
                            opening Europe in JN90AB
Nome:   europe_06122011.jpg
Dimensione: 60.8 KB
                            opening North America in JN90AB
Nome:   northamerica_06122011.jpg
Dimensione: 56.4 KB
                            opening South America in JN90AB
Nome:   southamerica_06122011.jpg
Dimensione: 53.9 KB
                            opening Oceania (VK-ZL included) in JN90AB
Nome:   oceania_06122011.jpg
Dimensione: 51.1 KB
                            opening Africa in JN90AB
Nome:   africa_06122011.jpg
Dimensione: 51.1 KB
                            openings in JN90AB
Nome:   tutti06122011.jpg
Dimensione: 132.1 KB
                            distribution by continent in JN90AB
Nome:   torta06122011.jpg
Dimensione: 53.4 KB
                            Notare la scarsezza quantitativa in assoluto dei QSO con Oceania, Africa e anche Sud America. Per Oceania e Africa è comprensibile , per il Sud America, un pò meno visto che di gente che trasmette da quelle parti non ce n'è poi così poca. Ovviamente, guai a trascurare questi continenti , visto che se è vero che danno pochi QSO, è anche vero che molto spesso ogni QSO è un nuovo country DXCC. Tra l'altro, essendo numericamente pochi gli spots relativi a questi continenti, anche il relativo grafico non è molto attendibile.
                            Inoltre, si conferma sinora una apertura e una chiusura della banda quasi coincidenti con l'alba e il tramonto del Sole.
                            Durante il contest, a parità di condizioni ionosferiche, probabilmente la banda sarà fruibile un pò di più, perchè ovviamente ci sarà più gente in radio.
                            Vediamo nei prossimi giorni come andranno le cose.
                              Condizioni peggiori anche oggi, rispetto ai giorni scorsi.
                              Speriamo che entro sabato le cose migliorino un pò.
                              Pochi JA oggi e comunque quantità complessiva di spots da tutti i continenti inferiore a quella dei giorni scorsi.
                              Ecco i grafici
Nome:   asia_07122011.jpg
Dimensione: 61.8 KB
Nome:   europe_07122011.jpg
Dimensione: 69.3 KB
Nome:   northamerica_07122011.jpg
Dimensione: 55.4 KB
Nome:   southamerica_07122011.jpg
Dimensione: 52.4 KB
Nome:   oceania_07122011.jpg
Dimensione: 51.0 KB
Nome:   africa_07122011.jpg
Dimensione: 50.3 KB
                              openings in JN90AB
Nome:   tutti07122011.jpg
Dimensione: 128.4 KB
Nome:   torta07122011.jpg
Dimensione: 54.0 KB
