[REALIZZATA] Antenna Delta-loop multibanda >40m
  • [REALIZZATA] Antenna Delta-loop multibanda >40m
    Salve amici,
    partendo dalla conosciuta e pluritestata M0PLK ho pensato di raddoppiare le dimensioni per poter raggiungere anche i 40m.
    Ovviamente ho subito optato per le canne in fibra di vetro, l'alluminio troppo pesante e "pericoloso". Conoscevo i tubi della spiderbeam, ho scambiato un paio di email con Rick DJ0IP:
    You don't have to double the size to get it to work effectively on 40m.
    Mounting the poles like this is about the worst possible thing you can do with them.
    If you make it just 9m per leg and feed it with openwire all the way to the shack, then place a 1:1 Guanella balun and then a tuner, it will work all bands as well. And it will be a lot stronger than having them 11m long.
    You will need some pretty hefty support for the arms.
    the most critical point is the point where the poles exit the support structure. That will be the point of most stress on The arms.
    the supports will need to be about 1.1m long, length adjusted exactly such that the fiberglass pole exits the support in the middle of the overlap between the first and second segment. At that point, which is about 10 cm long, the pole has double thickness since there are two segments.
    It is probably a good idea to cushion the poles inside of the support struts, which can be done with thin rubber strips. We have this stuff in 3mm thickness:
    http://www.spiderbeam.com/product_info.php?info=p190
    I cannot predict how well it will hold up.
    This is how I would do it.
    It uses the lower 9m of our 12m mast.
    Notice where the supports end. Exactly at the point of overlap...some of the overlap must be above the support.
    This is where it is strongest.
    But it is going to be a monster.
    Actually I would just build our 20m quad loop, run openwire all the way to the and be done with it.
    Much lighter and cheaper.
    Match as I said earlier.
    Loops are indeed great performers.
    I love them!
    Giovanni
    http://www.qrz.com/db/IZ7QSS
    Re: [REALIZZATA] Antenna Delta-loop multibanda >40m
    Mi pare un bel lavoro, come va ?
    Rispetto ad un dipolo rotativo 40-10m, pensi renda di più ? Dovrebbe in teoria.
    La piattina la lasci solo sul tetto o la porti in casa, cosa ahimè difficile ?
      Prima di realizzarla ho fatto mille simulazioni ed era assolutamente perfetta.
      Ho avuto anche un dipolo (in questo stesso QTH), questa doltona va assolutamente meglio. L'altra sera tardi sentivo in 20m sud-americani che facevano qso fra loro. Ho lavorato i nostri amici di TJ2TT in 10m con l'antenna di lato e arrivavano quasi 9 (di lato, da simulazione, perde 20dB +-).
      La scaletta arriva fino ad un guanella balun 1:1 (sistemato in quella scatoletta bianca posizionata sulla staffa a V), il balun a sua volta viene alimentato da 4 metri scarsi di coassiale collegato ad un ATU remoto (LDG AT1000ProII). Poi dall'ATU arrivo a casa con +- 30m di cavo coassiale.
      Per ora sono contento del lavoro fatto, le canne sono davvero fenomenali e robustissime.
      73,
      Giovanni
        Interessante... anche perchè permette di lavorare in continuità, con l'accordatore certo, tutte le bande intermedie.
        Inoltre il tuo è relativamente basso sul tetto, potendolo salire alcuni metri, credo che in qualche banda darebbe fino da torcere a qualche piccola direttiva, magari iper caricata, sarebbe carino provarlo.
        Le canne sono supporti eccezionali, flessibili e molto robusti.
          un lato del torrino è a strapiombo e dalle simulazioni, da quel lato risulta un guadagno superiore a una yagi 3 elementi (bande alte). Ovviamente parliamo di numeri su un pc, vi faccio sapere nella vita reale
          73,
          Giovanni
            Buonasera amici e buona Pasqua.
            Primo "crash-test" superato: https://www.facebook.com/giovanni.de...3852680024032/
            73,
            Giovanni
              Si riesce ad accordare con il tuner degli rtx comunemente usati?
              73 de Carlo iz7cdb
                Originariamente inviato da iz7cdb Visualizza il messaggio
                assolutamente sì, in alcune bande non avrai 1:1, sotto i 2,5 sicuro.
                io uso un LDG AT1000ProII
                73,
                Giovanni
                  Complimenti Giovanni
                  bel lavoro sia meccanico che elettrico! Spero ti dia
                  tanta soddisfazione in questo periodo di discesa del ciclo solare
                  73 Brix
                    grazie mille
                    73,
                    Giovanni
                      A direttività come se la cava sulle varie bande ? Ovviamente avanti fianco.
                        sulla carta +-20dB
                        non ho fatto prove accurate perché attualmente ho il rotore fermo
                        73,
                        Giovanni
