Petition to eliminate exclusive manual telegraphy band portions from the amateur spec
  • Petition to eliminate exclusive manual telegraphy band portions from the amateur spec
    Posto direttamente alla vostra attenzione, dal Newsgroup Glowbug una notizia assolutamente seria, con l'invito di farci sentire anche noi dall'Europa contro una decisione che dire insulsa è dir poco.
    TNX 73 de
    Alex I5SKK
    __________________________________________________ _
    I would recommend to anyone who operates or would like to operate, especially in the "high frequency" spectrum of the amateur bands (160 thru 10 meters and 6/2 meter bands and lower UHF bands) protest against FCC RM-11769 petition to eliminate "exclusive" existing CW allocation from ALL the "exclusive" bands now in use.
    The addition of other modes, especially digital modes or ANYTHING but extremely narrow bandwidth operation would not fit into "co-operative use" in the low end CW allocations of especially 160 thru 10 meter range where weak signal operations primarily take place. i.e.: the lower 25 khz of 80-10 meters.
    If this passes, some of the oldest type of radio communication we now use for simple CW transmission will be eliminated from future amateur spectrum now in use. There is only 30 days to reply to this petition. If it is passed, the oldest type of amateur operation technique known will be eliminated from future operations eventually, whether we like it or not.
    Please submit your opposition to RM-11769 as soon as possible.
    73 to all,
    Sandy Blaize W5TVW
    http://i5skk.blogspot.it/
    https://justhomemadehamradio.blogspot.it/
    Re: Petition to eliminate exclusive manual telegraphy band portions from the amateur
    Lascialo fare è americano..........cosa ci vuoi fare......
      Condivido pienamente quanto segnalato da Alex e la contrarietà a tale proposta di petizione per salvaguardare l'utilizzo del modo CW.
      E' tuttavia una petizione FCC per il band plan USA per cui non so in che modo potremmo se non esprimere solidarietà con coloro che condividono la difesa del CW.
      Saluti
      ".....Amending Part 97 of the Commission's Rules and Regulations to Redesignate Sub-Bands from Exclusively Morse Code to Narrowband Modes, including CW and for Other Purposes...."
      In effetti c'è già una serie di opposizione espresse alla modifica:
      http://apps.fcc.gov/ecfs/proceeding/...?name=RM-11769
      Ultima modifica di IK4AUY; 20-05-16, 20:51.
        Sergio,
        purtroppo la vera realtà dietro il tutto sta nella fatto che la lobby dei proprietari di barche da diporto di tipo privato che vuole poter usufruire della connessione Internet via radio e quindi senza pagare i vari providers.
        Questa gente è vero che se ne starebbe starebbe essenzialmente nelle zone Atlantiche loro, ma potrebbe anche girare il mondo e una volta dato il via allo smembramento o meglio allo "sp...ento" delle bande HF, specie porzione CW, sarebbe credo solo questione di tempo che per esempio anche ai proprietari di Yacht europei o limitrofi venisse tale idea...
        Farsi sentire anche se si tratta della FCC, credo almeno agiti le acque (mai cosa fu più azzeccata come terminologia...hi).
        Ma certo mala tempora currunt
        73 de aleSKK
        Ultima modifica di I5SKK; 21-05-16, 12:05.
          ... Mala tempora currunt, sed peiora parantur.
            ..c'è sempre la speranza che la ARRL si interessi della faccenda !!
