Solar cycle 24 - summary of last quarter August 2013 to October 2013
  • Solar cycle 24 - summary of last quarter August 2013 to October 2013
    (in italiano più giù)
    [click on the picture to full view]
    Let's see the situation with the solar cycle # 24.
    All data needed for the following charts comes from the Space Weather Canada, SIDC and WSO.
    Unless otherwise indicated, I refer the "adjusted" values of the solar flux, corrected (by Space Weather Canada) to refer to the average Earth-Sun distance (1 Astronomical Unit).
Nome:   ADJ 3-11-2013.jpg
Dimensione: 178.8 KB
    This is the graph of the solar flux on 2800MHz from the month of the previous minimum smoothed solar flux (October 2008) to the present. The blue curve is the monthly mean value of solar flux, while the red one is the smoothed value.
    It seems that the long-term trend is to decrease. Anyway, the high value of solar flux measured in october and that expected for november will affect the trend with a rise of the red curve (smoothed).
    The next chart is the comparison chart, in terms of Smoothed Sunspot Number, between the solar cycle #24 and all the previous ones.
Nome:   risalita cicli_novembre2013.jpg
Dimensione: 435.9 KB
    This chart starts from the month of the previous minimun smoothed sunspot number (december 2008).
    The curve of the solar cycle #24 is the red one. The smoothed value is always half that of the previous solar cycle , although there are of course some daily higher values of the solar flux, as that measured during the last CQWW SSB Contest.
    Now let's see how the inversion of the magnetic poles of the Sun evolves, putting as usual in Excel the data provided by the Wilcox Solar Observatory:
Nome:   wso_novembre 2013.jpg
Dimensione: 244.2 KB
    As you can see, now it seems also the southern hemisphere of the Sun has reversed the magnetic polarity (cyan curve smoothed), about one year and two months after the northern hemisphere (green curve smoothed). This difference in time seems to cause the presence of two peaks of solar activity. Now it seems we are experiencing the second peak. Will it ?
    The next update in early february 2014.
    [italiano]
    Vediamo la situazione del ciclo solare #24.
    Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada e dal SIDC. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica).
    Questo è il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva blu è quella del valore medio mensile del flusso solare, mentre quella rossa è quella del valore smoothed.
    Sembra che la tendenza a lungo termine sia ormai quella alla diminuzione. Tuttavia l'alto valore del flusso misurato a ottobre e quello atteso per novembre incideranno sull'andamento della curva smoothed con una leggera risalita.
    Il prossimo grafico è il grafico di confronto tra la risalita, in termini di Smoothed Sunspot Number, del ciclo solare #24 e quella dei cicli precedenti.
    Questo grafico parte dal mese del precedente minimo dello Smoothed Sunspot Number (dicembre 2008). La curva del ciclo solare 24 è quella rossa.
    I valori smoothed sono sempre la metà circa di quelli del ciclo precedente, nonostante, ovviamente, ci siano valori giornalieri del flusso più alti, come quelli misurati durante l'ultimo contest CQ WW DX SSB.
    Vediamo ora come evolve l'inversione dei poli magnetici del Sole, inserenedo come sempre in un foglio Excel i dati forniti dal Wilcox Solar Observatory.
    Come possiamo vedere, ora anche l'emisfero meridionale (curva ciano smoothed) sembra avere invertito la polarità magnetica , circa 1 anno e due mesi dopo l'emisfero settentrionale (curva verde smoothed).
    Questa differenza di tempo pare causare la presenza di due picchi di attività solare anche in questo ciclo. Adesso sembra che stiamo assistendo al secondo picco. Sarà così ?
    Il prossimo aggiornamento ai primi di febbraio 2014.
    Ultima modifica di IK7JWY; 04-11-13, 00:16.
    Re: Solar cycle 24 - summary of last quarter August 2013 to October 2013
    intanto forse è passata sotto tono questa notizia emanata dalla ARRL e che in fondo non dice nulla di nuovo per chi segue ormai da tempo l'evolversi della situazione:
    http://www.arrl.org/news/view/solar-...medium=twitter
      Si, dice cose ormai contante... MA non dice che da un punto di vista radioamatoriale, quindi non tanto attività solare, ma propagazione, gli ultimi 6 mesi sono stati tra i migliori di questi ciclo solare !
      In alcune giornate... anche settimane va, paragonabile ai cicli passati, che non è cosa da poco !
      Questo è stato possibile grazie a livelli di flusso e macchie cmq alti, ben oltre i 150 per molti giorni di seguito, nel periodo "giusto", vale a dire quello equinoziale... da fine agosto in poi, e soprattutto senza flare maggiori, che non hanno causato grossi problemi alla propagazione, che è risultata buona se non eccellente anche sulle bande più alte (KH9 in 10m.. ed i numeri realizzati in contest credo dicano molto...), ma decenti o buoni anche su quelle basse, per via dello scarso rumore (flusso e macchie alte si... ma poche emissioni di materiali... protoni, raggi x etc. etc.).
      Per me, personalmente, ma anche in generale (vedendo i risultati dei 2 CQWW e dell'appena passato ARRL 10m..), un bel momento per le HF.
      Onestamente, viste le premesse, forse mi aspettavo anche di peggio...
        Infatti, sarà per quello che "The scientists drew no specific conclusions regarding the impact of the extremely weak Cycle 24 on radio propagation."
        Almeno per ora godiamoci questa situazione. Se le previsioni per i prossimi anni saranno state azzeccate, ci sarà tempo per lamentarci sulle bande più alte
