To all the world packet cluster sysops
  • To all the world packet cluster sysops
    ZCZC
    14/05/2011 - To all the world sysops and all users of packet cluster
    In order to stop the growing immorality that populate our packet cluster network , we ask the sysops around the world to enable the password for single user access. The Sysop issues a password to any amateur who requests it. The system configured in this way will require at login BEFORE ANY ACTIVITY the username and the password assigned .
    Only registered users will be allowed to send spots or announces through the node while everybody will be allowed to do read-only activity.
    This procedure should at least reduce the misuse of the system, such as access to the packet cluster with the name of another ham (criminal offense of impersonation other identity), with fancy names or worse.
    Remain the fact that, if even only one Sysop not join to this initiative, we leave a backdoor that gave the possibility of continuing to abuse the packet cluster.
    WE COUNT HIGHLY on ITALIAN PRIDE : ALL THE ITALIAN NETWORK PCL provided with PASSWORDS !
    Experimentation started in recent days with IK4ICZ and IR4U who have already enabled access with passwords.
    Any password request will be very welcome by those two sysops.
    ITALIAN AND FOREIGN RADIO AMATEURS, ask your nearest SYSOP to join the initiative!
    (This follows up some discussions opened in Hamradioweb.org. You can read here:
    "DX Cluster: the beginning of a turn?"
    https://www.hamradioweb.org/forums/showthread.php?t=9662
    "Risk Behaviors"
    https://www.hamradioweb.org/forums/showthread.php?t=8974
    "Cluster 2.0 - give a try to spot rewrite rules .."
    https://www.hamradioweb.org/forums/showthread.php?t=7212
    "Bad things read on cluster"
    https://www.hamradioweb.org/forums/showthread.php?t=7164)
    Errors and Horrors on english version by Cristiano IZ0IEN
    NNNN
    Ultima modifica di IZ0IEN; 15-05-11, 10:41.
    Re: To all the world packet cluster sysops
    tnx fer info chris,
    r u english made ??
    I'm rural..
      tnx fer info chris,
      r u english made ??
      I'm rural..
      No, i'm not english made but i like the global english straightforward clarity to explain some concepts...
      .. in italian : "la stazione dx ascolta 5 khz sopra"
      .. in english : "5 up"
      Vy 73 de IZ0IEN
        no!
        in italian:
        ...peppino vai 5 sopra,vai 5 sopra che il dx ascolta 5 sopra,se chiami isoonda non ti sente,dai che e' appena passato iz.... quell'antipatico,vai 5 sopra a chiamarlo che vedrai che ti sente, anzi butta li' anche il mio nominativo che io lo ascolto bene e poi se ti risponde col mio call, vado avanti io,dai peppino chiamalo 5 sopra.... and after a long qso,
        all iso of course ,vai peppino cambiocambio
        2 seconds later:
        ITALIANI MACCARONI,BERLUSCONI,NINO ETC ETC
        1 seconds later: berlusconi a chi!? te tua sor e le generazioni passate presenti e future
        GO..GO...GO
        so...Im back to educational r5 alfa, no dx , quiet and relax
        Im sorry for all peppinos readings,its a fantasyname
          Please, gentlemen, this section of the forum is for english language only.
          Thanks for your cooperation.
            touchy .
              ZCZC
              The President of YASME foundation Mr. Wayne N7NG, engine and main sponsor of Dxsummit cluster, take act that spotting without registration is a bad thing that can involve useless flames, and starting from now he try to push up to DXsummit coders the implementation of mandatory registration/login prior to spot.
              A little milestone on the long way.
              I would to thanks publicly Mr. Wayne for hearing us, hope that help for the YASME work.
              Vy 73 de Cristiano IZ0IEN
