Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > DX'ing > DXpeditions by I.D.T. (until 5X3C 2019) > 9G-DXpedition
9G-DXpedition This forum is to share informations about the DXpedition 9G5TT & 9G5XX directly with the pilot station(IK7JWY). During the operations, feel free to put your questions or suggestions here. The official web site of the DXpedion is www.i2ysb.com . Have fun.
Vecchio 26-10-09, 17:21   #1
i1hjt
topband from Ghana
Dear topband enthusiasts
We are close to our departure data to Ghana.
Please visit our web page
http://www.i2ysb.com/
We know the country is not on the top rank in the most wanted for HF bands but we think there is enough interest for low bands to have fun being there.
We would like to focus part of our activity on 160m, we will set 1 station with a K3, a battle creek antenna for 80 - 160, 1KW amplifier. We are not aware about the possibility to set large receiving antennas, we will bring with us enough stuff to erect EWE, K9AY and, possibly, beverages.
We don't know yet how internet connection will be there, I recommend you to relay to this forum.
We will be in contact with our pilot daily, at least.
Any suggestion on the best time, operating modality etc. is welcome, please post it here.
Hoping to have all of you in log on 160,
Alfeo I1HJT
9G5TT & 9G5XX crew
i1hjt non  è collegato   Rispondi quotando
Vecchio 26-10-09, 17:52   #2
Re: topband from Ghana
Ho già il Ghana in 160 ma sono ugualmente curioso di vedere come andrà a finire, ti ricordi di fare qualche foto all' antenna, vero?
Vecchio 26-10-09, 18:42   #3
i1hjt
Ok porterò il grandangolo.
Alfeo I1HJT
Vecchio 27-10-09, 07:28   #4
i1hjt
Per Paolo I4EWH
Paolo, vista la tua esperienza nella topband, sarebbe utile un tuo commento e qualche indicazione sugli orari più indicati per collegare USA, Weast Coast, JA.
Ho ricevuto diverse mail dirette di commento e farò un sunto prossimamente in modo da creare una sorta di "road map". Ovviamente sarà poi tutta da verificare in base alla situazione locale (rumore, possibilità di montare antenne riceventi ecc.)
Grazie, Alfeo I1HJT
Vecchio 27-10-09, 09:28   #5
La situazione è questa:
Ghana Alba Tramonto
05.45 - 17.40
JA Alba Tramonto
21.00 - 07.40
USA W2 Alba Tramonto
11.30 - 21.45
USA W6 Alba Tramonto
14.15 - 01.00
Al tuo tramonto conviene puntare verso i JA e l' Asia in generale, poi attorno alle 21.00 c'è l' alba in Giappone e potrebbe essere il momento migliore per collegarli:
Nome:   Ghana-JA.jpg
Visite: 143
Dimensione:   52.0 KB
poi man mano che la gray-line avanza verso ovest dovresti avere i segnali dei russi a tutto vapore, ma quelli bene o male li fai sempre.
Attorno alle 22.00 dovresti avere un buon path verso la costa atlantica degli USA:
Nome:   Ghana-W2.jpg
Visite: 142
Dimensione:   50.6 KB
Poi si sposterà fino al middle-west e alla west-coast verso le 01.00
Nome:   Ghana-W6.jpg
Visite: 163
Dimensione:   43.9 KB
Però credo che la situazione migliore per fare i W6 sia un po' prima della tua alba:
Nome:   Ghana-W6 alba.jpg
Visite: 163
Dimensione:   73.1 KB
tralascio il sudamerica, quello ce l' hai nel cortile di casa, e l' Europa che bene o male si fa sempre. I problemi secondo me dovresti averli in ricezione, il QRM tropicale e gli eventuali temporali saranno una brutta gatta da pelare, una Beverage verso i JA e una verso gli USA sono praticamente un obbligo per ascoltare decentemente. Se vuoi tirare fuori anche le stazioni meno attrezzate un' altra verso l' Europa non sarebbe male. Tieni presente che se ascolti con 2 stazioni dalla stessa antenna (tipo una radio in 80 e una in 160) ti conviene usare uno splitter, tipo quello che ha proposto I7SWX in modo da condividere l' antenna senza che i 2 ricevitori si vedano fra loro. Se usi della potenza ti serve anche qualche filtro di banda.
Altrimenti puoi mettere una stazione in 80 o 160 a fare i JA e una in 40 a fare Europa ascoltando con 2 Beverage diverse, più tardi quando i JA spariscono lasci una stazione a fare Europa e una per gli USA. Insomma le soluzioni possibili sono tante, poi bisogna vedere anche come si comportano le bande alte perchè il rate maggiore lo fai lì e probabilmente il Ghana sarà ricercato anche in 10 e 12 metri vista la situazione degli ultimi anni, a quel punto finchè sono aperte meglio lavorare le alte.
Per ora mi sembra che non ci sia altro, comunque sono sempre a disposizione.
Buon divertimento!
Vecchio 27-10-09, 17:14   #6
i1hjt
Benissimo, Paolo, interessante la tua analisi.
Alcuni americani hanno suggerito cose analoghe.
Qualcuno dalla weast coast ha suggerito di chiamare in modo specifico per tacitare il "muro" di quelli della east coast. Pensavo anche di provare ad ascoltare "up & down" ad esempio up per la w.c. e down per la e.c. Non ci ho mai provato ma potrebbe funzionare, sopratutto lavorando qrs.
Non sappiamo ancora cosa useremo per la ricezione, la beverage è senza dubbio l'antenna più performante ma è de vedere se troviamo 200m liberi dove poter stendere il filo. E sperando che una volta steso non lo taglino, magari per venderlo...ci dovremmo portare una bobina di filo di alluminio, se ci stiamo con i pesi.
Grazie e a presto,
Alfeo I1HJT
Vecchio 27-10-09, 20:12   #7
Originariamente inviata da i1hjt Visualizza il messaggio
Puoi metterti d' accordo con qualche W6 che ti mandi un SMS nel momento in cui c'è apertura, poi penso che convenga chiamare semplicemente "only W6" altrimenti diventa un po' macchinoso spiegare a tutti quello che cerchi di fare.
In effetti il filo diventa un problema. MA siccome è sufficiente anche un filino sottile sottile potresti usare del rame smaltato da trasformatori che in pratica è invisibile, basta fare attenzione quando lo srotoli a non fare delle pieghe. Occorre però sospenderlo a un' altezza tale da non dare intralcio.
Anche un filo di alluminio va bene, oltretutto è più leggero del rame.
Buon divertimento!
Vecchio 08-11-09, 09:56   #8
i1hjt
Dear friends,
after the first info I drop on the top band reflector, I received a number of feedback mail.
I sum up hereafter the suggestions and our way to operate.
We will try and set the most efficient receiving antenna according to the local situation, we are not yet aware if it is possible to lay one or two beverages.
An inverted L and a 1K amplifier will be used for transmission. We hope the K3 receiver will make a great job. We will transmit out of the plain frequency (e.g. 1826.3) to avoid harmonics or birdies listening 3 - 5Khz split to help our correspondent to avoid the local interference (splatters).
The sunset in Ghana begins at 17:40Z almost at the same time as in Europe and Russia.
The grey line is across Japan from 20:30 to 21:45. During this time we will try stopping the European wall calling time by time JA and listening between 18:10 and 18:25.
At 21:45 the grey line reaches the East coast and it moves toward west, the most favourable time for West coast is during Ghana sunrise, starting from 05:00.
We will try to stop the European and East coast pile up (hopefully we'll get a pile up!) to give a chance to the West coast guys.
We cannot assure we will be on 160m every night, we will do our best to share operators and equipment with the other bands.
We hope the noise won't be too high.
Please feel free to drop here any suggestion and feedback.
We will keep our pilot station posted with the operation progress.
Best 73, Alfeo I1HJT
Tutti gli orari sono GMT +1. Attualmente sono le 11:29.
