Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > DX'ing > 9L-DXpedition
9L-DXpedition This forum is to share informations about the DXpedition 9L1X directly with the pilot stations (IS0VSG and IK7JWY). During the operations, feel free to put your questions or suggestions here. The official web site of the DXpedion is www.i2ysb.com where you can see the log on line. Have fun.
Chiudi la discussione
Vecchio 10-10-08, 08:56   #1
i1hjt
Last News - Ultime Notizie
Appena ricevuto da Vinicio, sono a Freetown, a breve la partenza per Shebro.
Alfeo I1HJT
i1hjt non   collegato
Vecchio 10-10-08, 15:28   #2
L'avatar di IK7JWY
ubicazione: Alezio-LE-
Riferimento: 9l1x
Last news received right now from Silvano I2YSB.
They are on the Sherbro Island, after a 5 hours trip on a ship. They would be on air in 2-3 hours.
Appena ricevute da Silvano I2YSB info belle fresche
Sono sull'isola, dopo 5 ore di barca !
Dovrebbero essere in aria tra 2-3 ore.
73 de ik7jwy Art
Ultima modifica di IK7JWY; 10-10-08 a 15:34
IK7JWY non   collegato
Vecchio 11-10-08, 10:23   #3
L'avatar di IK7JWY
Riferimento: Last News - Ultime Notizie
Last news from the team: they are installing the second spiderbeam antenna. They will come back on air soon.
Ultime notizie dal team: stanno installando la seconda spiderbeam. Torneranno in aria presto.
73 de ik7jwy Art
Vecchio 11-10-08, 12:59   #4
L'avatar di IK7JWY
Last News: now on air with 3 operating stations.
Ultime notizie: hanno appena ripreso le operazioni, ora sono attivi con tutte e tre le stazioni.
73 de ik7jwy Art
Vecchio 11-10-08, 17:46   #5
L'avatar di IK7JWY
first picture from 9L received right now from the team
la prima foto appena ricevuta dal team
Nome:   9L1X-1.JPG
Visite: 718
Dimensione:   122.6 KB
73 de ik7jwy Art
Vecchio 12-10-08, 11:13   #6
L'avatar di IK7JWY
Last news from the team: yesterday evening they had a heavy thunderstorm, lasted all the night ! So, the low bands has been unserviceable unless for a few minutes.
The team plans to continue the SSB acitivity in 20m band, becouse they have huge pile-ups. The conditions on 20m are good until 00:00 UTC.
They tried later on 40m and 80m bands but without signals, maybe becouse of the thunderstorm.
Today about 00:00 UTC they will try again on 40m and 80m bands SSB.
Every morning from 06:30 to 07:30 UTC they will be on 20m calling JA, via the short and the long path.
Ultime notizie dal team: ieri sera abbiamo avuto un fortissimo temporale che e' durato tutta la notte. Le bande basse sono state praticamente
inutilizzabili tranne qualche sporadico momento.
In SSB attualmente restiamo in 20 metri perche' abbiamo pile up furiosi e quindi inutile andare ad operare su altre bande. La propagazione in 20 tiene bene fino alle 24 utc circa in 20 metri. Abbiamo provato i 40 e gli 80 ma
praticamente non arrivavano segnali, forse il temporale!
Stasera verso le 24 utc proveremo ancora in ssb sia in 40 che in 80.
Ogni mattina verso dalle 6,30 circa fino alle 7,30 circa UTC saremo in SSB con particolare attenzione per JA provando sia via lunga che via corta.
73 de ik7jwy Art
Vecchio 13-10-08, 13:21   #7
L'avatar di IK7JWY
Last news from the team (via I1HJT, tnx): everything OK. The only one trouble is to work on the lower bands. Every nights rain and thunderstorm and the noise is so high to make impossible to operate on 40m, 80m and 160m. The antennas are among the trees, so isn't easy to find out a better setup.
The water of the river close to te location is dirty , so no swimming, there are also the crocodiles...
Ultime notizie dal team (via I1HJT, tnx): Tutto procede ok, l'unico problema sono le bande basse, tutte le notti piove e ci sono temporali, il noise e le scariche sono molto forti tanto da rendere difficoltoso operare in 40m, figurarsi in 80 e 160. Tra l'altro le antenne sono in mezzo alla vegetazione e non è facile trovare sistemazioni ottimali. L'acqua lì vicino è quella della foce del fiume, è sp.orca a quindi niente bagni, e ci sono anche i coccodrilli!
73 de ik7jwy Art
Vecchio 14-10-08, 14:35   #8
L'avatar di IK7JWY
Last News from the team
160m band .... nothing to do... we'll try the last days.
80m band .... idem ... : no signal , ssb or cw
40m band ... good signals in cw but unserviceable in SSB mode.
Yesterday evening we tried to work someone through the I2ZGC's net but we made 10 QSOs only , then nothing.
20m band.... still good ...
today afternoon, about at 13:00UTC we'll try the 17m band in SSB mode (15m band if no conditions on 17m), then we'll be on 12m and 10m CW.
Today morning we tried again to work JA and VK on 20m but nothing to do.
Yesterday evening at 22:00UTC we worked some JA and VK via the long path
This evening we'll try again.
So, everything OK but the continous thunderstorms for days , generating heavy noise and a lot of mosquitoes (we have also the crocodiles near the shack... HI )
Another picture from our location.
160 .... niente da fare ... proveremo gli ultimi giorni.
80.... idem ... nessun segnale ne in ssb ne in cw
40... buoni segnali in cw ma ssb impraticabile... ieri sera
abbiamo provato perfino a stare con il net di i2zgc ma siamo
riusciti a fare solo 10 qso e poi non abbiamo sentito p[iu
nulla.
20.... tirano ancora bene ... oggi pomeriggio proveremo i 18
mhz in ssb (o i 21 in caso di brutta propagazione) verso le
13 utc e faremo 24 e 28 in cw.
Stamattina abbiamo provato ancora una possibile apertura su
JA e VK in 20 metri ma niente da fare .... ieri sera alle 22
utc in 20 metri abbiamo fatto alcuni JA e VK via lunga ....
anche stasera proveremo la stessa cosa.
Per il resto tutto apposto a parte continui temporali che
generano noise elevato e prolificare di zanzare (abbiamo
pure i coccodrilli vicino alle postazioni... hi hi hi !!!!).
Un'altra foto dal posto dove siamo.
Nome:   9L1X-2.JPG
Visite: 683
Dimensione:   116.3 KB
73 de ik7jwy Art
Vecchio 15-10-08, 14:40   #9
L'avatar di IK7JWY
Tonight we had a very strong thunderstorm with a lot of wind , but around 03:00UTC we have been able to do something more than 300 QSOs in 80m band CW . We had a trouble with one of our spiderbeam antennas: guy rope broken and antenna fallen down. We had to work under the rain but now the antenna is OK.
Questa notte abbiamo avuto un fortissimo temporale e vento
ma nonostante tutto, verso le 3 utc, siamo riusciti a fare
qualche 300 e passa qso in 80. Abbiamo avuto un problema con
una spiderbeam .... sono saltati i tiranti ed e' caduta...
abbiamo lavorato sotto l'acqua ma adesso è di nuovo
operativa.
Nome:   SSB SPIDERBEAM.JPG
Visite: 695
Dimensione:   160.0 KB
73 de ik7jwy Art
Vecchio 16-10-08, 15:10   #10
L'avatar di IK7JWY
At last an evening without thunderstorm ! We have been able to do some QSOs on 40m SSB: a wall of europeans , all very strong signals and a very hard effort to manage the pile up. Altough working by number the QRM was heavy. Worked USA also on 40m SSB, also with them many problems due to in band broadcasting stations.
Anyway everything is OK. This afternoon we will work on 15m SSB. We expect a heavy pile-up.
To eveyone waiting for 160m, please hold on and be patient, the weather conditions are still no good.
Finalmente una sera senza temporale e siamo riusciti a fare
qualche qso in 40 metri ssb .... muro di europei tutti
fortissimi e una fatica bestiale a gestire il pile up ...
anche andando per numeri il bordello era totale.... fatto
anche gli USA ma anche con quelli parecchi problemi per
forti segnali di broadcasting.... cmq tutto procede bene ...
oggi pomeriggio faremo attivita in ssb in 15 ... ci
aspettiamo un forte pile up.
A chi chiede i 160 devono portare pazienza.... le condizioni
sono ancora non favorevoli.
73 de ik7jwy Art
Vecchio 17-10-08, 14:46   #11
L'avatar di IK7JWY
From this evening we could be able to give more time to the activity on 80m. Yesterdary evening again thunderstorm and heavy noise. We have been able to work on 40m CW only. On 40m SSB we made something but the band was almost unserviceable, so we returned on 20m until 00:00UTC. Later no SSB signals in all the bands... Yesterday evening we worked as well in 20m RTTY mode.
Today morning we installed the 160m antenna... We hope the noise give us some chance to do something... If the conditions will be OK, we will try on 160m.
Da stasera dovremmo riuscire a dedicare piu
tempo agli 80 cw ... ieri sera ancora temporale e noise
molto alto..... siamo riusciti a lavorare solo i 40 metri in
cw ... in fonia abbiamo fatto qualche cosa ma era quasi
impraticabile e quindi siamo tornati a fare un po di 20
metri fino alle 24 utc ... poi buio totale su tutte le
bande per la ssb .... ieri sera abbiamo lavorate bene anche
in 20 rtty.
Stamattina abbiamo montato la antenna per i 160 ....
speriamo che il noise ci dia la possibilita di fare qualche
cosa ... se ci saranno le condizioni proveremo.
73 de ik7jwy Art
Vecchio 17-10-08, 15:09   #12
L'avatar di IK7JWY
Last News from the team (via I1HJT, tnx)
The 9L1X team will try on 160m tonight at 22:00Z
Later more news about.
Il team 9L1X far un tentativo in 160m stasera alle 22,00Z.
Seguiranno altre notizie in merito.
73 de ik7jwy Art
Vecchio 17-10-08, 20:30   #13
L'avatar di IK7JWY
The 9L1X team will try on 160m tonight at 22:00Z. TX frequency 1825,5 kHz, QSX 1830-1835 kHz
Il team 9L1X far un tentativo in 160m stasera alle 22,00Z, frequenza di trasmissione 1825,5 kHz, ascolto da 1830 a 1835 kHz.
73 de ik7jwy Art
Vecchio 18-10-08, 12:28   #14
L'avatar di IK7JWY
Tonight we have been able, at last, to be active on 160m, although a thunderstorm and a very high noise.
Many signals on 160m but everyone 5 kHz up, no spreading out. At 6 kHz up no signal , so we had only one continous CW note. Too many CW signals in the same frequency, it was very hard to decode the single callsigns.
So, if you want that we work the 160m, please follow the instructions given by the operator: spread out. He is listening to 5 kHz *and* up.
We worked 80m also, with a lot of strong signals from USA. We know that many europeans asked QSY in the EU band, but we had a S9+20db noise and the only ones we was able to listen to were the USA stations. Anyway, we worked some european also, but with a very hard effort.
Around 02:00 UTC we had a strong thunderstorm and although the good conditions on 80m we had to put off the radios becouse of the heavy lightning. We hope that not happens this evening again. Anyway, all the antennas are OK.
Now an important note about the dupes. There are many stations working us two , three times on the same band and in the same mode... They make QRM only. If they are in the log, it is useless to work us again, becouse we don't add them in the log again. So, they make QRM only.
Today we will try on 10m and 12m again. Yesterday we tried many time on these bands but without success. We hope today it will be better.
La scorsa notte siamo finalmente riusciti a lavorare i 160
anche se con temporale e noise altissimo.
In 160 sentivamo molti segnali ma tutti lavoravano 5 khz
sopra e non allargavano lo split.... gia a 6 khz non c'era
piu' nessuno.... praticamente avevamo una nota unica e per
noi e' difficoltoso poter decifrare i nominativi... quindi,
se vogliono che lavoriamo i 160, devono seguire le
istruzioni che da' l'operatore, ovvero allargare lo split e
andare anche oltre i 5 khz....
Abbiamo anche lavorato gli 80 ssb con segnali strepitosi
dagli usa ... sappiamo che molti europei chiedevano qsy in
banda europea ma avevamo noise a 9+20 e gli unici segnali
che sentivamo erano quelli dagli usa... cmq qualche europeo
lo abbiamo fatto ma con molta fatica.... verso le 2 urc
abbiamo avuto un fortissimo temporale e nonostante la
propagazione fantastica in 80 abbiamo dovuto spegnere tutto
per fulmini.... speriamo non si ripeta questa sera... cmq le
antenne hanno resistito.
Nota importante in merito ai
doppi.... ci sono numerosissime stazioni che ci collegano la
seconda o terza volta sulla stessa banda.... creano solo
casino e niente altro.... se sono a log e' perfettamente
inutile collegarci la seconda volta anche perche' noi non li
inseriamo... quindi creano solo casino e niente altro.
Per il resto tutto ok .... oggi proveremo anche i 10 e 12
metri... ieri ho fatto parecchie puntate sulle bande alte ma
abbiamo fatto solo 2 qso.... speriamo oggi vada meglio.
73 de ik7jwy Art
Ultima modifica di IK7JWY; 18-10-08 a 12:32
Vecchio 19-10-08, 19:04   #15
L'avatar di IK7JWY
Yesterday evening we had the usual thunderstorm... a very strong thunderstorm and we had to put down the antennas as a precaution. Activity limited becouse of noise, just some QSO on 40m and 80m SSB.
Then we had to put off the radio as a precaution. The thunderbolts stroke near our location. It was better not to risk.
We hope this evening to be able to do something , becouse when the noise is low, we have strong signals from EU , USA and JA.
Usual good conditions at 22:00 UTC via long path on 20m with the JA's, with signals over S9.
Ultime Notizie dal team
Ieri sera abbiamo avuto un fortissimo temporale e abbiamo
dovuto abbassare le antenne per sicurezza.... attivita'
molto limitata dovuta a noise ... giusto qualche qso in 40 e
80 ssb ma a un certo punto abbiamo dovuto spegnere tutto per
sicurezza.... i fulmini cadevano vicino e non era il caso
rischiare ... speriamo stasera di riuscire a fare qualche
cosa anche perche' nei momenti di poco noise i segnali che
riceviamo sono forti sia da EU che da USA che da JA.
Solita apertura alle 22 urc via lunga con i JA con segnali
oltre il 9in 20 metri.
73 de ik7jwy Art
Ultima modifica di IK7JWY; 19-10-08 a 19:39
Vecchio 21-10-08, 15:27   #16
L'avatar di IK7JWY
The team will continue the on air activity up to 07:00 UTC of october 23. They will leave the island at 11:00 UTC same day.
Il team continuer le operazioni fino alle 07:00 UTC del 23 ottobre. Lasceranno l'isola alle 11:00 UTC dello stesso giorno.
73 de ik7jwy Art
Vecchio 23-10-08, 10:25   #17
L'avatar di IK7JWY
The 9L1X DXpedition is ended today october 23 at 06:08 UTC.
Le attivit in aria della DXpedition 9L1X sono terminate oggi 23 ottobre alle 06:08 UTC.
73 de ik7jwy Art
Vecchio 25-10-08, 14:53   #18
L'avatar di IK7JWY
Eccovi i nostri amici sani e salvi, appena rientrati. (TNX I1HJT)
Nome:   IMGP6920_piccola.JPG
Visite: 201
Dimensione:   82.5 KB
73 de ik7jwy Art
Tutti gli orari sono GMT +1. Attualmente sono le 19:12.
