K4 Elecraft or not ??
  • K4 Elecraft or not ??
    Updated, E' vero per davvero.. eccola pagina web sul sito della Elecraft
    https://elecraft.com/products/k4-transceiver
    Il Boss di Elecraft con K3 e K4
    La brochure in PDF
    Come forse saprete, domani si apre Hamvention 2019, a Dyton Ohio, la più grande fiera radiantistica in America, quindi sicuramente verrà presentato il nuovo K4, ci saranno foto e video in quantità immagino...
    Elecraft K4 Transceiver
    HIGH-PERFORMANCE DIRECT-SAMPLING SDR
    • DIRECT SAMPLING + OPTIONAL SUPERHET (HDR) MODULE
    Direct sampling allows for advanced filtering, NR, NB, noise nulling, etc.;
    Optional HDR module provides the ultimate in dynamic range
    • 160-6 M, ALL MODES, 100 W / 10 W; WIDEBAND DUAL RECEIVE
    Main/sub receivers can be on same or different bands; single or dual panadapters
    • MODULAR ARCHITECTURE
    Add HDR module, future 15 watt VHF/UHF module, etc., as needed
    • OPTIMIZED USER INTERFACE
    Encoders for VFO A, VFO B, RIT/XIT offset; many user-programmable controls
    • HIGH-PERFORMANCE TUNING AID
    High resolution mini-pan, per-receiver, for accurate tuning & search
    • NO-COMPROMISES CW
    Silent PIN-diode T/R; fast QSK; many features for CW ops
    • EXTENDED I/O
    HDMI, Ethernet, analog/digital audio; ATU with 3 ant. jacks; up to 5 RX ant. sources
    • VERSATILE SOFTWARE ENGINE
    Powerful, fast-booting CPU accommodates future in-box software applications
    • PORTABILITY
    Light weight, low current drain – compatible with field operation
    A direct-sampling SDR you’ll love to use
    Our new K4 harnesses the latest in signal processing while retaining the best aspects of the K3S and P3. The resulting user interface makes the technology transparent, allowing you to focus on working the world.
    160-6 meter, all-mode coverage & dual RX
    The K4 includes dual receive over 100 kHz to 54 MHz. Since it utilizes direct sampling, there’s no need for crystal filters in the K4 or K4D (see Models, back page). For extreme-signal environments, we offer a dual superhet module (standard in the K4HD). An internal VHF/UHF module is also planned.
    High-resolution mini-pan for each receiver
    Our advanced fine-tuning aid, with its resampled bandwidth as narrow as +/- 1 kHz, is displayed separately from the main panadapter. You can turn it on by tapping either receiver’s S-meter or by tapping on a signal of interest.
    Simple operation and setup
    The K4 features a large, full-color touch display, combined with a rich set of real controls. Per-VFO transmit metering makes split mode completely foolproof. Band-stacking switches and per-receiver controls are both intuitive and versatile, adapting to operating context. Usage information on these and other features is just one tap away, thanks to our built-in help system.
    Rich I/O complement
    The rear panel includes all the RF, analog and digital I/O you’ll need to complete your station. All K-line accessories are supported, including amps, ATUs, and our K-Pod station controller. The HDMI video output supports an external display with its own user-specified format.
    Full remote control from multiple devices
    The K4 can be 100% remote controlled, via Ethernet, from a second K4 as well as a PC, notebook, or tablet. Panadapter data is included in all remote displays.
    Modular hybrid architecture
    The K4 adapts to your needs, with three models to choose from: basic K4 with wide-range dual receive; K4D, with diversity receive; and K4HD, with a dual superhet module for exceptional dynamic range. You can upgrade or add options as desired, or as new technology becomes available. This extensibility applies to software as well. The K4's powerful, fast-starting CPU provides unlimited expansion opportunities.
    Ultima modifica di IZ5CML; 17-05-19, 08:33.
    Re: K4 Elecraft or not ??
    ...un amico OM con cui ero stamani per lavoro mi ha detto di aver ricevuto notizie in tal senso dal noto tecnico felsineo, da lui incontrato giorni fa.
    Pare che sia la risposta Elecraft ai 7610 e 101DX (confesso che quest'ultimo mi attizza molto)
    Il prezzo si dice sia comunque sulla fascia alta del mercato ovvero oltre i sopracitati apparecchi e concorrenti knw... (dalle cifre ipotizzate ci compri il 101DX-Mp, un 9700 per v-u e ti fanno il resto)
    Ma comunque è tutto "radio serva"
    _
    Ultima modifica di iw5eij; 16-05-19, 16:15.
      Queste dovrebbero essere le caratteristiche, quindi una radio SDR.
      NO-COMPROMISES CW
      • EXTENDED I/O
      • PORTABILITY
      Rich I/O complement
        Radio SDR con modulo opzionale analogico per chi vuole una dinamica molto alta.
        Costerà presumo un rene e mezzo.
          Originariamente inviato da I2NOY Visualizza il messaggio
          ..ti sbagli , un rene, due polmoni , cellule staminali e riabilitazione per due anni, siamo oltre i 5K $
          Ultima modifica di IM0QMA; 17-05-19, 09:28.
            Una radio top gamma non costa mai poco, penso anche io che in Italia si aggirerà sui 6mila euro, in più va detto che i prodotti made in USA sono da anni molto cari qui da noi, per via di dazi che tra l'altro minacciano di alzare ancora.
            Sicuramente il K4 avrà numeri molto importanti nei vari test, ma almeno in Europa, la concorrenza di 7610 e FT-101D (per ora la radio con i numeri di laboratorio migliori....), che costano meno di 4mila euro, sarà bestiale, difficile convincere un europeo a sborsare quasi il doppio... poi per carità, c'è chi spende 3mila euro per un "lineare" da 500w scarse...
            Per quanto mi riguarda, ho una radio di 18 anni, che è destinata a resistere ancora un bel pò, quindi... per il mio basso livello di attività, avanza, però è affascinante vedere cose il mercato propone.
            Ah dimenticavo, strano che abbiano aggiunto nel K4, la possibilità di decodificare e lavorare senza un PC, direttamente dalla radio, CW (!) RTTY e PSK31, modi che ormai nessuno più pratica... avrei scommesso che gli americani di Elecraft avrebbero avuto l'esclusiva per i modi del signor Taylor, con quello si, avrebbero distrutto completamente la concorrenza in perfetto stile americano, democraticamente a cannonate !
            Ultima modifica di IZ5CML; 17-05-19, 14:59.
              Ma basta con la politica!
              Per inciso, se il signor Taylor volesse cedere un suo prodotto d'ingegno a chiunque, con un regolare contratto e pagando le tasse, non avrebbe fatto che i suoi interessi, in modo perfettamente legale.
              Se Elecraft avesse comprato l'esclusiva del prodotto ideato da Taylor, potrebbe sfruttarlo come vuole e se distruggesse la concorrenza, questa si farà più furba in futuro.
              Si chiama libero mercato!
              Ultima modifica di I2NOY; 17-05-19, 16:47.
                Beh, non mi risulta che chi ha inventato il PSK o l'RTTY prenda compensi... il tutto è di libero uso
                  Quando si diffuse l'FT8 c'era chi paventava una successiva versione a pagamento...
                    Reverse Paypal pileup, ci arriveremo.. non disperare..
                      Se avessi 4-5.000 € da spendere non cambierei certo radio ma l'alluminio sul tetto , per ora l'ultima folle spesa sono stati 43 € per un QCX in 40 metri (in 20 ce l'ho gia') e mio diverto
                        Una degli aspetti più belli della radio è proprio codesto, in onde corte ci si può divertire con mezzi davvero minimi, i conti in tasca non si devono fare, ma onestamente, soprattutto con le prestazioni che tutte le radio hanno attualmente (dimostrato ampiamente dal fatto che sia in stazioni da contest vincenti, sia a casa di dxer che non perdono un dx ci sono radio di tutti i generi, nuove ma anche di 30 anni fa !!!!) e direi anche da diversi anni, qualsiasi tipo di attività, anche la più elitaria come il top contesting, è alla portata, quindi vale davvero il giusto.
                        La radio ormai è diventato un oggetto di complemento, chi può compra la radio visivamente dei suoi sogni, che gli riempie l'occhio e la stazione, e fa bene ci mancherebbe, a chi non piacerebbe un 7851 ?!
                        Ma poi, se davvero ci piace fare dx e collegamenti al limite, quello che conta sono ben altre cose, dal tempo dedicato alla location in cui si opera, dalle antenne a come queste sono installate, la radio non fa mai la differenza, se non per la propria soddisfazione ed ego, cmq non da trascurare.
                          Non girarmi la frittata.
                          Tu hai scritto che se Taylor avesse venduto ad Elecraft la possibilità di includere FT8 nel firmware del suo nuovo K4, avrebbe ammazzato la concorrenza.
                          Dato che il protcollo FT8 è di libero uso (addirittura Taylor ha pure pubblicato i sorgenti per vari hardware e sistemi operativi) il fatto che fosse inserito nel K4 non avrebbe precluso tutti noi di usarlo con un PC connesso al nostro RTX.
                          Non che ami gli americani, ma "sparare" sempre a senso unico mi infastidisce.
                            Non mi sembra che abbia scritto questo... ho scritto che pensavo che Elecraft averebbe avuto l'esclusiva da Taylor, gratis o meno non fa differenza.
                            E poi sei stato a dire che Taylor avrebbe potuto vendere regolarmente e pagarci le tasse... ma allora, sti codici sono di pubblico dominio o meno ?
                            Ultima modifica di IZ5CML; 20-05-19, 12:10.
                              Io non parlavo di FT8 nella mia prima replica, ma ti facevo un esempio generico di come funziona il mondo in questo momento.
                              Dato che ci sono almeno altri 2 o 3 programmi free che usano il codice di Taylor (JTDX, MSHV e JS8Call), presumo il codice sia di pubblico dominio, magari con qualche clausola di citare Taylor come realizzatore del engine core.
                              Mi fermo qui, sono cose noiose e un po' OT.
