Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > VHF and UP / Satellites / EME
Vecchio 26-08-12, 20:00   #1
i4fyf
Registrato dal: Jan 2009
ubicazione: Forli' - name: Fabio
cerco info "elpro"
chi conosce la "elpro" ??
ho un ampli fm mod 4500 e non so' nulla..
fabio
i4fyf non   collegato   Rispondi quotando
Vecchio 26-08-12, 20:37   #2
IK0OZD
Guest
Messaggi: n/a
Re: cerco info "elpro"
BROADCAST FM AMPLIFIER
Range frequency: 87.5 - 108 MHz
INNOVACTION Mod. ROCK 1K3
Power output: 1300 Watt RF................................................ .......
Specifications:
Power supply: 230 V.a.c. 50 Hz
Power input: 20 Watt RF
Power output: (adjustable) 200 at 1300 Watt RF
Protection on every part
Technical characteristics
RF Input connector: "N" Female
RF Output connector: "7/16" Female
Front out connector (BNC) for the
RF measurements (TEST -40 dB
Output connector for external power supply exciter
(230 V.a.c.) with voltage drop in case of intervention
protection (prevents damage to the transmitter)
Connector for control "REMOTE" outside
Protection: SWR (standing wave)
Absorption in excessive current
High temperature
Excess pilot input, etc ...
Button on front panel for any "RESET"
of protection (in case of intervention)
Forced-air cooling.
RF filter for attenuation
of frequencies
harmonics integrated.
Buttons on front panel for setting
readings on the display.
LCD backlit panel for the
visualization of the functions:
Reading of the RF output power direct, reflected,
current consumption in operation (Amperes),
supply voltage to the RF power MOSFET,
internal temperature etc ...
pescar-inter 0-2 snejder-milito pe mo
  Rispondi quotando
Vecchio 26-08-12, 20:38   #3
IK0OZD
Guest
Messaggi: n/a
in itagliano puro
:::::::::::: ::::::::::::::::::::::::::::::::::::::::::::: Caratteristiche tecniche Connettore di ingresso RF : "N" femmina RF Connettore in uscita: "7/16" femmina frontale out (BNC) per le misure RF TEST (-40 dB Connettore di uscita per eccitatore alimentazione esterna (230 Vac) con caduta di tensione in caso di intervento di protezione ( previene i danni al trasmettitore) Connettore per il controllo "REMOTE" al di fuori di protezione: SWR (onda stazionaria) Assorbimento in corrente eccessiva per alte temperature intervento del pilota in eccesso, ecc ... pulsante sul pannello frontale per un "RESET" di protezione (in caso di intervento ) . Raffreddamento ad aria forzata RF filtro per l'attenuazione delle frequenze . armoniche integrati tasti sul pannello frontale per impostare le letture sul display. pannello LCD retroilluminato per la visualizzazione delle funzioni: Lettura della potenza RF diretta, riflessa, il consumo di corrente in funzione (Ampere), la tensione di alimentazione del MOSFET di potenza RF, ecc temperatura interna ... pescar-Inter 0-2 Snejder-Milito pe mo
  Rispondi quotando
Vecchio 27-08-12, 05:53   #4
i4fyf
ma dove hai copiato??????
monta la 1500 ?
notare i 2 trasformatori molto sovradimensionati nonostante sia a 220.
sopratutto il "piccolo" se e' per il filamento e' veramente enorme..
fabio
Nome:   CIMG4280.jpg‎
Visite: 174
Dimensione:   303.6 KB
Vecchio 27-08-12, 06:41   #5
IK0OZD
Guest
Messaggi: n/a
vedi se trovi qualcosa qui
http://radiotimefirenze.altervista.o...e_tecnico.html
dalle indicazioni che hai dato risulta essere questo come marca e modello
http://www.ebay.it/itm/BROADCAST-FM-...t_11229wt_1399
  Rispondi quotando
Vecchio 27-08-12, 12:43   #6
i4fyf
ho visto il trafo per il filamento, e' posizionato sotto il vano valvola,
il grande e' per l'anodica, mancano info per quello a sx in foto..
allego 2 foto di un onesto rake fm, sempre valvola 1500
ma una differenza abissale nell'alimentatore
tony, quello che hai trovato non c'entra, il mio 4500 e' una macchina anni 80.
fabio
Nome:   CIMG4285.jpg
Visite: 188
Dimensione:   337.0 KB
Nome:   CIMG4286.jpg‎
Visite: 179
Dimensione:   276.0 KB
Ultima modifica di i4fyf; 27-08-12 a 12:49
Vecchio 01-09-12, 14:00   #7
i4fyf
eccoli....
Nome:   CIMG4290.jpg‎
Visite: 173
Dimensione:   231.2 KB
ID: 7910   Clicca sull'immagine per ingrandirla
Nome:   CIMG4257.jpg‎
Visite: 182
Dimensione:   380.4 KB
Tutti gli orari sono GMT +1. Attualmente sono le 18:03.
