Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > DX'ing > 9Q0HQ
9Q0HQ This forum is to share informations about the DXpedition in Congo directly with the HF pilot station (IK7JWY for HF and IK0FTA for 6m). During the operations, feel free to put your questions or suggestions here. The official web site of the DXpedion is www.i2ysb.com . Have fun.
Vecchio 13-03-15, 20:45   #1
py2xb
Registrato dal: Apr 2011
160m !!!
Hi Guys
Do you have any info on Top Band operation ? I also would like to know where the team is located. Is it a Hotel ? Is it noisy for low bands ?
Team is doing a wonderful job. Thanks for 6m qso. First time ever I heard 9Q on six.
Regards Fred - PY2XB
py2xb non   collegato   Rispondi quotando
Vecchio 14-03-15, 02:16   #2
I9/7446
L'avatar di I9/7446
Registrato dal: Oct 2013
Re: 160m !!!
No, sorry no info about location.
At present time only someone flash qsy for testing on 160MT.
You can to look the teem member spot on cluster , by IK2HKT.
Usually they write info and call cq ( for a test tx/ rx antenna on 160mt) immediately.
Your swl report in the cluster about topband, from PY, is appreciated also.
MEMBER-DELETED
I9/7446 non   collegato   Rispondi quotando
Vecchio 14-03-15, 10:57   #3
L'avatar di IK7JWY
ubicazione: Alezio-LE-
Re: 160m !!!
Here is the inverted-L for 160. The vertical side is 20m high.
Nome:   160mt.jpg
Visite: 211
Dimensione:   222.1 KB
in this picture you can also see the location. The ground around is wet and it seems to be good.
73 de ik7jwy Art
Vecchio 17-03-15, 01:04   #4
L'avatar di IK7JWY
Re: 160m !!!
directly from the team:
"we have thunderstorm, almost every afternoon, with lightning and heavy noise. Conditions are difficult on 80 and 160. In the evening the signals are very week and often below the noise level. Something better at sunrise, when signals become stronger. This morning we worked on 80 despite the noise. No condition on the 160. The next days we'll try to improve something and to give more time to the 160, weather permitting."
73 de ik7jwy Art
Vecchio 21-03-15, 12:15   #5
L'avatar di IK7JWY
Re: 160m !!!
continue efforts to improve the performances on the low bands. We have assembled a EWE instead of other RX antennas, it seems to be better in noise suppression. For transmission, this morning we worked a lot to mount four elevated radial for the 160 vertical antenna. Long enough the calibration, each radial must be calibrated independently and then the antenna, as a finishing touch. Tonight we will evaluate, will be useful feedback from our listeners.
Unfortunately, the low bands are very noisy, two nights ago we did a fair amount of activity but very little last night because the noise was too strong and it does not allows to decode the signals even though we heard that there were many people calling us.
Who puts comment on the cluster should try to stay on this side and have to deal with noise, maybe at his home did not.
continuano gli sforzi per migliorare le performances nelle bande basse. Abbiamo montato una EWE al posto delle altre antenne rx, sembra essere migliore nella diminuzione del rumore. Per la trasmissione, stamattina abbiamo lavorato parecchio per montare 4 radiali sollevati per la verticale dei 160m. Abbastanza lunghe le operazioni di taratura, ogni radiale deve essere tarato indipendentemente e dopo l'antenna, come tocco finale. Stanotte la valuteremo, saranno utili i feedback da parte di chi ci ascolta.
Purtroppo le bande basse sono molto rumorose, 2 notti fa abbiamo fatto una discreta attivit ma la notte scorsa pochissimo perch le scariche erano troppo forti e non ci permettevano di decodificare i segnali nonostante si sentisse che c'era molta gente che ci chiamava.
Chi mette gli spot di commento dovrebbe provare a stare da questa parte della barricata e fare i conti col noise, che magari a casa sua non ha.
73 de ik7jwy Art
Ultima modifica di IK7JWY; 21-03-15 a 23:53
Tutti gli orari sono GMT +1. Attualmente sono le 13:13.
