Vai indietro   hamradioweb.org > Discussioni / Areas of discussion > DX'ing > 9Q0HQ
9Q0HQ This forum is to share informations about the DXpedition in Congo directly with the HF pilot station (IK7JWY for HF and IK0FTA for 6m). During the operations, feel free to put your questions or suggestions here. The official web site of the DXpedion is www.i2ysb.com . Have fun.
Vecchio 24-03-15, 20:02   #1
L'avatar di IK7JWY
ubicazione: Alezio-LE-
Post latest news
Since one week we have problems with power supply with frequent black-outs. Today the power Company has exceeded, from late morning we are without power and we are going on with a local generator, a Perkins 15 years old and it has its faults. After a while the engine overheats and we have to stop it for cooling. The electric load is not balanced, so we have to leave off the air conditioners. With 35 °C and high wet, it's not a pleasure to stand in the shack. Furthermore, the voltage is low, so the linear amplifiers goes automatically in stand by and we work with 100W only. We know the power Company is doing some works, we hope these end up before tonight.
Tonight we'll work mainly on the low bands trying to do as mush QSOs as possibile, hoping the power returns. If not, we'll work with 100W only, so you have to open your ears..
Tomorrow early morning we'll start to uninstall the antennas. We will be active on air with a station only until late morning/early afternoon, local conditions permitting.
The return to Italy is scheduled for Thursday morning.
direttamente dal team:
Da circa una settimana abbiamo problemi con l'alimentazione elettrica e frequenti interruzioni ma oggi l'ente elettrico si è superato, è dalla tarda mattinata che siamo senza energia e andiamo col generatore interno. Questo è un vecchio Perkins con 15 anni di carriera e manifesta i suoi acciacchi. Dopo un pò di tempo il motore si surriscalda e occorre fermarlo perché si possa raffreddare.
Il carico elettrico delle fasi non è equilibrato pertanto dobbiamo rinunciare ai condizionatori, con 35 gradi e umidità elevatissima non è piacere rimanere davanti alle radio.
Inoltre la tensione è così bassa che i lineari spessissimo si sganciano, stiamo lavorando con i 100W dei K3.
Sappiamo che l'ente elettrico sta facendo dei lavori che si spera finiscano prima di notte anche se qui, nel momento in cui scrivo, è ormai quasi buio.
Stanotte opereremo prevalentemente sulle bande basse cercando quanti più contatti possibile, con la speranza che l'alimentazione elettrica venga ripristinatala. Se così non fosse, si farà il possibile con 100W ma voi dovrete aguzzare aguzzare le orecchie!
Domattina presto cominceremo a smantellare le attrezzature, dovremo rimanere operativi con una stazione fino a tarda mattinata - primo pomeriggio ma dipenderà dalle circostanze locali.
Il rientro in Italia è previsto per giovedì mattina.
73 de ik7jwy Art
Ultima modifica di IK7JWY; 24-03-15 a 23:01
Tutti gli orari sono GMT +1. Attualmente sono le 15:35.
