Thread Tools Display Modes
Old 02-02-12, 15:02   #1
Post Solar cycle 24 - summary of last quarter November-December2011 to January2012
I summarize what happened in the last quarter to solar activity.
All data necessary for the preparation of the following charts , I have personally done with Excel, have been built from Space Weather Canada. You will therefore notice that I speak only of solar flux at 2800 MHz. I chose to take only this parameter for the study of solar activity because certainly more reliable and objective than the sunspot number. To note, however, that there is a correlation between solar flux and 2800MHz on the number of sunspots.
I refer, in such plots, unless otherwise indicated, the values "adjusted" of the solar flux, correct (by the Space Weather Canada) to refer to the average Earth-Sun distance (1 astronomical unit), since the actual Earth-Sun distance increases and decreases in summer and winter.
These are the charts of the last three months.
November 2011
Name:	flusso adj novembre 2011.jpg
December 2011
Name:	flusso adj dicembre 2011.jpg
January 2012
Name:	flusso adj gennaio 2012.jpg
The next one is the graph of the solar flux on 2800MHz from the month of the minimum smoothed solar flux (October 2008) to the present. The red curve is the average monthly value of solar flux, while the blue one is the smoothed value. The data considered are the flux "Adjusted", derived from those physically measured by the Observatory of Penticton (Canada).
Name:	risalita ciclo 24 _ febbraio 2012.jpg
Considerations.
In the last quarter, particularly in the months of December and January, the solar activity in terms of sunspot number and solar flux on 2800 MHz has been decreasing compared to previous months. This is particularly noticeable from the graph showing the monthly average value of solar flux (adjusted), above. At the moment, however, everything conforms to the natural evolution of the solar cycle, wich is approaching, with ups and downs, its maximum expected the next year.
Now the graph (in terms of Smoothed Sunspot Number) comparing the rising of the solar cycle #24 and that of previous solar cycles:
Name:	risalita cicli 1749_2012_febbraio 2012.jpg
The curve of the solar cycle #24 is the one with the red squares.
As you can see, up to now the solar cycle has reached or exceeded, in terms of SSN, the solar cycles #1, #5, #6, #7, #12 and #14.
The current solar cycle and the previous one ? I updated the graph where you can see the rising of the two cycles, the#23 and the #24.
Name:	confronto cicli 23 e 24 _ febbraio 2012.jpg
The solar cycle #24 remains below the previous one, as evidenced by the smoothed curves.
The next update in early may 2012.
[fare click sulle immagini per ingrandirle]
Come di consueto, riassumo quanto si è potuto constatare nell'ultimo trimestre a livello di attività solare.
Tutti i dati necessari per l'elaborazione dei grafici seguenti, da me personalmente eseguita con Excel, sono stati ricavati da Space Weather Canada. Noterete, quindi, che si parlerà in essi esclusivamente di flusso solare sui 2800 MHz. Ho scelto di adottare solo questo parametro per lo studio dell'attività solare perchè sicuramente più attendibile e obiettivo rispetto al numero di macchie solari. Per il significato e modalità di misura del Solar Flux @2800MHz rinvio all'articoletto n.2 in formato acrobat a suo tempo pubblicato su questo forum. Da tenere presente, in ogni caso, che esiste una correlazione tra flusso solare sui 2800MHz e numero di macchie solari, di cui parlo brevemente sempre nell'articoletto acrobat sopra richiamato. Faccio, inoltre, riferimento, in questi grafici, se non diversamente indicato, ai valori "adjusted" del flusso solare, ossia corretti (sempre dallo Space Weather Canada) per riferirli alla distanza media Terra-Sole (1 Unità Astronomica), considerato che la distanza effettiva Terra-Sole aumenta in estate e diminuisce in inverno. Anche questo particolare aspetto viene brevemente spiegato nell'articoletto acrobat sopra richiamato.
Questi sono i grafici degli ultimi tre mesi.
Novembre 2011
Dicembre 2011
Gennaio 2012
Riporto ora il grafico relativo all'andamento del flusso solare sui 2800MHz dal mese del minimo del flusso solare smoothed (ottobre 2008) fino all'attualità. La curva rossa è quella del valore medio mensile del flusso solare, mentre quella blu è quella del valore smoothed. Circa la modalità di calcolo del valore smoothed rinvio al solito articoletto n.2 in formato acrobat.
Dati considerati, quelli del flusso "adjusted", derivati da quelli fisicamente misurati dall'osservatorio di Penticton (Canada).
Considerazioni
Nell'ultimo trimestre, in particolare nei mesi di dicembre e gennaio, l'attività solare, in termini di numero di macchie solari e del flusso solare su 2800 MHz è andata calando rispetto ai mesi precedenti. Ciò è particolarmente evidente dal grafico che mostra il valore medio mensile del flusso solare (aggiustato), di cui sopra. Al momento, però, tutto è conforme alla naturale evoluzione del ciclo solare, che si sta avvicinando, con alti e bassi, al suo massimo previsto il prossimo anno.
Ho aggiornato il grafico comparativo tra la risalita in termini di SSN del ciclo solare 24 e quella dei cicli precedenti
La curva del ciclo solare 24 è quella con i quadratini rossi
Come potete vedere, fino ad oggi il ciclo solare #24 ha raggiunto o superato, in termini di SSN, i cicli solari # 1, # 5, # 6, # 7, # 12 e # 14.
Cosa possiamo dire circa l'attuale ciclo solare e quello precedente ? Ho aggiornato anche l'altro grafico dove si vedono le risalite di questi due cicli solari:
Il ciclo solare #24 resta al disotto di quello precedente, come attestato dalla curva smoothed.
Il prossimo aggiornamento ai primi di maggio 2012.
73 de ik7jwy Art
Old 02-02-12, 22:27   #2
Re: Solar cycle 24 - summary of last quarter November-December2011 to January2012
Come potete vedere, fino ad oggi il ciclo solare #24 ha raggiunto o superato, in termini di SSN, i cicli solari # 1, # 4, # 5, # 6 # 12 e # 14.
Non molto da aggiungere a quanto detto, se non che questo ciclo si comprta in maniera "anomala".
Non è assoggettabile appunto ai primi cicli conteggiati, che sono anche i meno intensi, lo è stato nel suo inizio, stentatissimo, per i primi 10-12mesi dal minimo, con valori davvero bassi, ma poi l'attività è salita molto, una svolta verso l'alto che lo fa adesso assomigliare più agli ultimi 5-6 cicli solari a noi più vicini, che, va detto, rappresentano anche uno dei periodi (1955-2007..) con l'attività solare più alta osservata dall'uomo, ma che comunque non raggiunge e probabilmente non raggiungerà nemmeno nel suo massimo, previsto ancora per il 2013.
Ha "fregato" tutti all'inzio la Nasa ed altri scienziati, che addirittura prevedevano un ciclo molto intenso, come il 23 o forse di più, e poi chi, ancora poco meno di 1 anno fà, lo considerava ormai "finito" senza mai nemmeno cominciare per davvero, chi ravvedeva segni di un ciclo "abortito" o addirittura macchie con polarità invertite segno, già(!?) del ciclo 25 !
Ridiamoci un pò su, l'uomo ha sempre una fretta cane di capire gli eventi, per catalogarli (ciclo intenso come xyz - ciclo debole come yzx etc.) ed avere in qlc modo certezze (senza le quali vive male..), e quando gli eventi naturali sono così lunghi e lenti come un ciclo solare, la fretta gioca brutti scherzi.
Thread Tools
Display Modes
